I have list of ledgers extract from tally…I need to create Chat of Accounts masters in AX on the basis of that. the file has following kind of imformation…Equity Share Captial under this heading there is some data…Sundry Creditors. followed by some data…sundry debtors followed by some data and so on…
please help me on how will create Chart of Accounts in the above scenario
for example: equity capital can be set as Header and the related accounts can be as Balance/Liability accounts under equity capital header. like the way you do it for others. When we are building COA, we have to take care of the number sequence for each group or set of accounts for classification, like Assets would be started with 9##### and Liablities would be starting with 8#####
Yes, we can very well use ledger account catagories for classifying ledger accounts. my earlier answer was more focusing on overall structuring of COA list.
Just a suggestion from my side. While grouping COA, keep in mind the schedules (Balance Sheet, PL) because at last when you will bw making financial statement this will help you.
It will be better if you discuss with your client as well.
I am actually going to follow your earlier Answer which is more fruitful…thanks… now my only concern is do i need to create Debtors and Creditors again while creating Chart of Accounts??
