Please find below my requirements to be implemented by SysOperationFramework:
need to add a button(simple) as if user clicks there, an info message regarding format of file to be displayed.
I M unable to clear the previous values in the fields ,may I request your guidance regarding Pack and Unpack in sysoperation framework??
Can you elaborate your requirements, please? I also suggest you split your two questions to two separate threads.
And please attach a tag with your version of AX.
My requirement is :
On dialog box, I need to put a BUTTON(not a menu item button), On clicking, an info message must be shown for example “Hello World”(i.e.,).
I can see, through sysoperation, I can only add a MenuItemButton. Please guide.
First of all, you again forgot your version of AX. SysOperation framework exists in both AX 2012 and AX 7.
Also, how do you build the dialog?
Version - Ax 2012
I have built 4 classes, based upon the need and functionality. The classes are: UIBuilder, Contract,Services, Controller.
Thanks - I’ve attached the tag for you this time.
I know these classes; it tells me nothing about your problem.
Hi Martin,
Thanks for your help ! I can’t see the tag.
You still haven’t told me anything about your problem, so let me assume that you’re trying to extend the automatically generated UI builder, you’ve created a custom UI builder class but you don’t know either how to add the button or how to react to a click. Nevertheless you don’t need any help regarding the message.
In that case, override build() method of your UI builder class and put code like this there:
FormBuildButtonControl button;
super();
button = this.dialog().formBuildDesign().addControl(FormControlType::Button, 'MyButton');
button.registerOverrideMethod(methodStr(FormButtonControl, clicked), methodStr(MyUIBuilder, buttonClicked), this);
Change names as appropriate in your case.
Note that the method running on button click must accept a single parameter of type FormButtonControl.
Thanks Martin ! This works, in addition to this, can you please let me know, if the methods in line number 6 where to be added? in which class?
It’s up to you. My code above says that it’s a method in MyUIBuilder class and the instance is the current object (this). You can use any other class by changing these parameters.
Thanks ! But I need only an Info message. I don’t think, I have to write any method. Your valuable comments please
Hmm, and where will you put your code if not into a method? Try it and you’ll see…
I am getting following error:
Stack trace: The method has been called with an invalid number of parameters.
Stack trace
(C)\Classes[UIBuilder class name]\method(new)
If I am running the same method separately, It is running fine, but it is throwing me error, if I am using the following syntax:
button.registerOverrideMethod(methodStr(FormButtonControl, clicked), methodStr(UIBuilder class name, method(new)), this);
This is not valid X++ code. Please give your actual code, so I don’t have to guess what’s a bug and what’s just caused by imprecise copying.
If you really try to use a constructor (new()), then it makes no sense and obviously can’t work. Use a method with the parameter type explained above.
