Hi ,
I want to open the File browser in my dialog.
How to achieve this using Sys operation framework?
Kindly guide.
Thanks & Regards,
Chutti
Hi ,
Kindly guide.
Thanks & Regards,
Chutti
not sure of SysOperation Framework
but there is a example in the standard ax form itself go to forms>> tutorial_Form_File
please have a look.
I usually use the following code in dialog method:
YourdialogField = dialog.addFieldValue(typeid(FilenameSave), YourVariable,LabelText,HelpText)
YourVariable will contain path and filename
Hope it helps,
regards,
Thomas
Thanks for your reply.
I have tried this in Runbase class and it is working fine.
But I want this same logic to be implemented using Sys operation framework.
Can dialog() be used in sys operation framework ?
Thanks & Regards,
Chutti
It works fine in Runbase.
Want to know how to implement the same in Sys operation framework
Thanks & Regards,
Chutti
UI is now handled by UI builder classes, so that should be your preferred approach.
You can also use your own template form (and override templateForm() method on your controller) or even to use a completely independent form if you don’t want controls generated from your contract (but it’s a little bit more work).
