vv1984
1
i’ve got a single table holding records of two kind, the difference is in a field “category”, it can be “CAT A” and “CAT B”.
Now, i’ve got two different forms which retrieve data from the same table, but form 1 is supposed to display only “CAT A”
records, and form 2 only “CAT B” ones.
How do I achieve this the best? Do i have to use a query as data source for my form? Or can it be done via X++ inside
the form’s init() method?
thank you in advance
regards
hi
u can uses the querybuildframework
thnks,
srikanth
wblack1
3
Add the query as a method to the datasource you are filtering the data on within the form, you need to use init() as well as you said.
vv1984
4
How do i add the query to the form’s datasource via X++ ?
Thank you for your help
u need to write the code …
Right-click methods and then add a new method
Then as Srikanth said then write the code for your query and modify Init()
