How to filter Data Using "SELECT" statement in a form in AX 2012
Hi to all,
Can anyone please help me with the issue, I know i can filter record using query in a form in AX 2012,
but how to filter the record using “select” statement in a form in AX 2012.
Thanks in Advance.
Alonso
It’s not possible. Use the query framework.
Your question is not so precise so I’ll try to give you leads:
-Filtering records using query in form: you cann add an executeQuery() method on your form datasource like follows
this.query().datasourceNo(1).addrange(fieldnum(yourTable,yourfieldyouwanttofilteron)).value(valueyouwanttofilteron);
I’m using AX 2009 but I think this works in AX 2012
  • in AX 2009, I never user select statement in form, can you be more specific?
regards,
Thomas
Hi Thomas,
Thanks for the reply…actually i want to display Purchase req Workflow approvers in a form, so i thought writing select statement will be easy to get the records…
Alonso
Thanks Martin for the reply…,
