i have added a string field that needs to be inserted along with other fields in CustInvoiceJour table whenever a sales invoice is posted.
i have tried calling the method in the init() of the table, as well as in SalesInvoiceCreateJournal,InitJournalHeader() however no result.
what i am trying to do is, whenever a record is posted to custInvoiceJour, i need to update a string field from the InvoiceDate field on the table.
any ideas?
Hi Lola,
Whenever u post sales invoice , SalesFormInvoiceContranct Class is called. see here and debug u can find the right place .
Hello,
thanks for your reply.
i have tried debugging the class but it has not method that directly updates the custinvoicejour.
i just need to tell the system to update a field in custinvoicejour (or custinvoicetable i can use this instead too) whenever a new record is inserted in the table.
the other field will be updated according to this method:
custInvoiceJour.DateHijri = Global::ConvertGregorianToHijri(CustInvoiceJour.InvoiceDate);
so where can i place this assignment method?
(have also tried placing it on the init() and the insert() but no luck)
Hi Lola,
i have a same problem, did u get the solution? pl share the solution…
refer to the class salesinvoicejournalcreate method :initJournalHeader
CustInvoiceJour table is updated from initFromSalesParmTable or initFromLedgerJournalTrans methods, the update that you made in insert method should be work fine , but you need "Generate incremental CIL (Ctrl+shift+f7) in the AOT to refresh the code because part of process invoice runs on CIL.
Regards
