How to send custom field value from salestable to custinvoicejour ?
I have added one checkbox in salestable form and when I do invoice it is reflect to custInoiveJournal form.
Thanks in advance.
You can easily find the answer by yourself. Think about it - isn’t there already code for all the standard fields? You can use cross-references to find out how it works for standard fields and then do the same for your custom field.
Notice that CustInvoiceJour has initFromSalesTable() method, which gets a SalesTable buffer as a parameter. It’s called from SalesInvoiceJournalCreate.initInvoiceHeaderFromSourceTable(), but you don’t have to worry about it. You can simply use CoC on initFromSalesTable() to initialize your extra field.
Thanks Martin,
But when I Click Invoice menubutton from saleorder it should reflect to CustInvoiceJour table. Any suggestion
Sorry, I have no idea what you’re talking about. Can you please give us more details about your problem?
I thought you wanted to copy a file from SalesTable to CustInvoiceJour when posting an invoice and that’s what I’ve explained above.
I have added below code for my requirement it is working.
[ExtensionOf(classStr(SalesInvoiceJournalCreateBase))]
final class SalesInvoiceJournalCreateBase_Extension
    protected void createJournalHeader()
        SalesParmTable      salesParmTable;
        CustInvoiceJour     custInvoiceJour;
        SalesTable          salesTable;
        next createJournalHeader();
        custInvoiceJour = this.getJournal();
        salesParmTable  = this.parmParmTable();
        salesTable      = SalesTable::find(salesParmTable.salesID);
        if(salesTable.DIPLIsChecked)
            custInvoiceJour.selectforUpdate(true);
            custInvoiceJour.IsChecked = salesTable.IsChecked;
            custInvoiceJour.doupdate();
