We have an extension with the following event subscriber
[EventSubscriber(Objecttype::Table, Database::“Sales Line”, ‘OnAfterDeleteEvent’, ‘’, false, false)]
When we run the extension normally everything works, but when we do the following in a test codeunit
SalesLine.Delete(true);
The quantity is 0 in the sales line in OnAfterDelete Event
This only happens when running a test codeunit
We isolated the issue to this code in the SalesLine.dal (line 3000 and something)
// In case we have roundings on VAT or Sales Tax, we should update some other line
if (Type <> Type::" ") and ("Line No." <> 0) and ("Attached to Line No." = 0) and ("Job Contract Entry No." = 0) and
(Quantity <> 0) and (Amount <> 0) and (Amount <> "Amount Including VAT") and not StatusCheckSuspended
then begin
Quantity := 0;
"Quantity (Base)" := 0;
"Qty. to Invoice" := 0;
"Qty. to Invoice (Base)" := 0;
"Line Discount Amount" := 0;
"Inv. Discount Amount" := 0;
"Inv. Disc. Amount to Invoice" := 0;
UpdateAmounts();
end;
We had similar issues with Qty modifications and were able to work aorund this with TestPages:
SalesOrderSubform.OpenEdit();
SalesOrderSubform.GoToKey(SalesDocTypeEnum::"Order", SalesHeader."No.", SalesLineNo);
SalesOrderSubform.Quantity.SetValue(10);
SalesOrderSubform.OK.Invoke();
Unfortunately, there doesn’t seem to be a method in the SalesOrderSubfrom test page to delete a line
Anyone else seeing this or suggest any workaounds
