I need some help, How can I add a fields in Unposted Purchase Header table and the fields being added can also be seen in Posted Purch. Inv. Header when the transaction is posted?
Is there a lot of codding to do about this guy’s? Where can I locate the exact code for this one?
Thank you in advance guy’s. Your help would be so much appreciated.
Purchase header table uses TRANSFERFIELDS function to copy from Purchase Header to Purch. Rcpt. Header and Purch. Rcpt. Header…
Help Says…
TRANSFERFIELDS copies fields based on the Field No. property of the fields. For each field in Record (the destination), the contents of the field with the same Field No. in FromRecord (the source) will be copied, if such a field exists.
The fields must have the same data type for the copying to succeed (text and code are convertible, other types are not.) There must be room for the actual length of the contents of the field to be copied in the field to which it is to be copied. If any of these conditions are not fulfilled, a run-time error will occur.
So as suggested by Amol, just add the field with same ID in both tables…
