I am creating sales order by using x++.
I have also need to create miscellaneous charges for the sales order.
I don’t know how to add miscellaneous charges in the sales order programmatically. Please help me.
Thanks in advance,
Hari
Thanks in advance,
Hari
You should use the MarkupTrans table, it stores Miscellaneous charges for a specific sales order.
I had a quick look, I’d use initform… and insert() methods, called by you code passing salesTable buffer as parm
You haven’t provided sample code you use to create your salesOrder, so Ican’t tell you more
regards,
Thomas
for reference see \Data Dictionary\Tables\ShipCarrierPackage\Methods\createMiscCharge
