Add Field In Field Group
hello
Please Help me how I can Add Other Table Field In Second Table
How I can DO this
thanks for help me
regards
ali
Hi ali, could you please explain what you’re doing? I didn’t get what you mean by adding a field in second table.
hello sir
i mean i have 2 teble
1 inventtesttable
2 inventtestanalysisline
inventtestanalysisline have a Field Group in this Group have many Field
But i want Add inventtesttable Fields In INVENTTESTANAYLSISLINE TABLE
GROUP
HOW
I THING YOU WILL UNDERSTAND MY PROBLAMS
I guess you mean a group control in a form… In that case, ensure yourself that the control isn’t set with AutoDataGroup = Yes. Then just drop a field into the group there as usual. If you still have any problem with it, please explain what happens.
If you really mean a field group on a table, the answer is simple: you can’t use fields from other tables there.
Thank you martin sir that table field group issue
Hi Ali,
you can write a display method in lines table and drag and drop the same into the field group of lines table.
Thanks & Regards,
Britto John Baskar.A
