Hi
I want to write a code for a button to open a new form.
Can you help me to find some tutorials and links to do so .
Thanks in advance .
Hi
Thanks in advance .
On the button clicked event, write something like this -
void clicked()
Args args = new Args();
MenuFunction menuFunction;
menuFunction = new MenuFunction(menuitemdisplaystr(SalesTable), MenuItemType::Display);
menuFunction.run(args);
thank you so much
You can use this code,
FormRun formRun;
VendTable vendTable_filtered;
select vendTable_filtered where vendTable_filtered.AccountNum == “1001”;
args.name(formstr(VendTable));
args.record(vendTable_filtered);
formRun = classfactory.formRunClass(args);
formRun.init();
formRun.run();
formRun.detach();
thank’s for answer…
your code is really use full…
