zero-terminated string error
Hi Raul / DenSter,
Thanks for your great support. Thankfully I am able to make that happen. Only thing is that whenever I add any string into message queue, code unit gets executed and gives following error.
This message is for C/AL programmers:The stream cannot find a zero-terminated string.The stream may be invalid, or the (variable or requested) size may be too small.
I am not able to figure out the problem.
Please help
