Thanks for your great support. Thankfully I am able to make that happen. Only thing is that whenever I add any string into message queue, code unit gets executed and gives following error.
This message is for C/AL programmers:The stream cannot find a zero-terminated string.The stream may be invalid, or the (variable or requested) size may be too small.
MQBus Automation ‘Navision MS-Message Queue Bus Adapter’.MSMQBusAdapter
CC2 Automation 'Navision Communication Component version '.CommunicationComponent → WithEvents = Yes.
InMsg Automation ‘Navision Communication Component version 2’.InMessage
InS InStream
Txt Text (100)
Can you please tell me which variable’s dimension I need to change.
