i have problem in standard item journal . i want to create consumed entry from standard item journal then this error show to me " you must specify source no in item journal line journal template name item journal batch name default line no 1000"
I go to item journal template table then add new code but it not show also why this problem made and how i solve this problem
OK thanks but now i need to add source no in item journal line it show as dim and drop down menu fixed and not accept write how i solve this if possinle
I am having the same problem mentioned in the subject. The consumption journal requests an item number, which I have included on the journal line. But the system still gives me the following error message: “Source No. must have a value in Item Journal Line: Journal Template Name = CONSUMP, Journal Batch Name = DEFAULT, Line No = 10000. It cannot be zero or empty” I see no place where an actual ‘Source No.’ can be entered, even if I go back to the Item Journal Templates. Does this make any sense to you?
