Not always correct - as Nuno said above, if user’s (client’s) licence contains any or all of
7,110 Report & Dataport Designer 7,120 Form Designer 7,130 Table Designer> 7,140 XML Port Designer
granules, enduser can do the respective changes/modifications.
First two are included in BRL Bussiness Essentials, all of them - in BRL Advanced Management licence, if you are still on module based licencing, you must buy them separately.
updated: forgot to mention - there are some “protected” objects, for modifying them you really need Dev.License, but normally enduser will never will (should not [;)] ) try to modify them, and, objects with numbers in “protected area”, as those from AddOns etc.
Thank you for information, I have realy got some new important knowledg.
I wanna to add that I can not create or modified (desighn) any type of new object.
By the way, how I can check the type of licence?
The interesting detail is that the programmer, who works before looks like used the same account details and could be able to create/design some objects.
If you make tools → License Information You can see your license information. Previous developer could use another license, for example from a partner.
