I did say I removed the <> in order to proceed further, thank you for varifying that it was the correct method. You guys rock and I’ll remember the info in the future. The LOG says this from the Export:
XML ERROR in Table
REASON: Bad Value
FILE: C:\Documents and Settings" "\Local Settings\Temp\Customer List.xml
GROUP: Cell
TAG: Data
VALUE: 000.000.0000
If I change the number of records to less than what is in the table it does not allow me to export them. It gives me a number of records in table exceeded <3000> etc.
I’m under the impression that you guys are probably right and the issues are unrelated, but if changing the number didn’t cause the issue to arise then I’m still at a loss.
Hi you may have to test where the limit ends. Depending on the data type integer and long integer have different maximum number. Although, I am not sure, I will probably test for
(2^n)-1 that is less than 10000 [i.e. 2 raised to power n]
e.g. if my ‘n’ is 5 it will be (2^5)-1 = 31
You probably will be able to figure out the right ‘n’ in the equation.
I kind of understand what you’re saying but I’m not exactly sure where you expect me to apply that knowledge to. I am pretty new to NAV. (novice)
Can you elaborate a bit more? I understand that applications vary depending on code structure for integer data types, I.E. SQL uses BigInt, C uses Long and even though the represntations are the same the ending values are different.
What I don’t understand is how you intend for me to use this knowledge for NAV’s front end to figure out where the issue is…
The records I am trying to export belong to the Customer table. I’m just doing an import straight out of it, into Excel. I believe you are correct, it seems there is some bad data somewhere, but I can’t seem to find it.
That value or any values similar to it do not exist in the customer table rows… I’ve looked pretty extensively. I was wondering, would running SQL Profiler help in this case? I feel that the dataport happens on the NAV application side and is a communication between it’s programming and MS Excel. I don’t think I would see anything on the SQL side, but it’s a thought.
I was actually in the progress of editing my earlier post when I got called into a meeting and the User Groups forum expired my post time… shame.
Ok, so I didn’t bother with trying to cut the data up. I Exported it from SQL into Excel instead. I went into the data from there and discovered that the record value of the “Phone No_” column in the Customer table had been set to “000.000.0000”. I guess XML does not like decimal values in it’s export process of a varchar column, because there are other values of “000-000-0000” that seem to export just fine. After changing the value, the export began to work again.
