I am getting the following error while importing an xpo to an AX Instance. There is no map object in the xpo.
Error : The value “he” is not found in the map.
Could anybody please give a solution ?
Monika.
Monika.
Does it showing error for all xpo file imports?
Check whether you are trying to import the object of a different ax version.
What are type of objects you are trying to import.
The error does not mean you are trying to import a map - the meaning may be the object type you are trying to import does not exists.
