In output order I wanted to reduce the inventory order quantity through x++ coding so that I can create a new output order . how to edit a output order using x++ in order to adjust the shipped quantity of transfer order in ax 2012, please suggest a solution.
Anyone please help where the values for those two condition are saved or fetched to avoid that warning mentioned this is stopping me from creating a output order for the given transfer order. please suggest a solution
Hi kranthi,
I could make out this method, but i just want to know which table field value this maxqty and maxCWQty represents so that I can write a job to increase the value more than 0 to make create a output order. Please help with a solution kranthi
