hi,
plz let me know how to solve the following problem :
1.If there are two or more tables and sum on a particular field is required with proper grouping.
2.How to excute IN / Not IN in x++ ?
3.How to write subquery like SQL server 2008 in x++.
hi,
You could always try using a direct sql call via a sql connection if you are having trouble with queries in x++. Something like:
UserConnection userConnection;
Statement statement;
SqlStatementExecutePermission sqlPermission;
ResultSet resultSet;
str sql;
sql += ’ SELECT * FROM CUSTTABLE’;
sql = strfmt(sql); // format the query
userConnection = new UserConnection(); // create connection object
statement = userConnection.createStatement(); // create statement
sqlPermission = new SqlStatementExecutePermission(sql); // create and assert SQL statement execute permission
sqlPermission.assert();
resultSet = statement.executeQuery(sql); // assign return of query to resultSet
CodeAccessPermission::revertAssert(); // limit the scope of the assert call
