I am trying to write big text (xml pasing by webservice to CU) to a file. It type conversion error error when i try to write through output stream
ostream.WriteText(input);
if i use write then it says invalid file mode…
any help?
reagards,
any help?
reagards,
Why do you read this XML stream into a bigtext instead of an XMLport or XMLDOM automation variable?
Please explain what exactly you want to achieve.
