Good afternoon,
I’ve created a table called certification with 2 fields(code and description). Code field is an extended datatype created by me.
In Vendtable in group vendor i’ve insert the code field like a combobox with you can choose for that itemid the name of certification.
Inside the method of the code i’ve created a modified method:
public boolean modified()
boolean ret;
ret = super();
vendtable.CertificationId = certification.Code;
return ret;
with this method i write the vendtable the cetification.
the problem is that when i open the table vendtable inside the article i find the certification while i open the form in group vendor i see anything.
I want to see in the field code the same things.
Someone can help me!
