where i can write the code in the user setup table…plz suggest me
Why do you need this?
Is it for a customer or Training purpose?
this is for only training purpose.
Thanks alot mohana for ur replies…even u r not giving any suggestion i will struck up here only…because i very new to this one…thank for helping me…
Did you set Register Time field to true in User Setup table?
Then it will calculate the time of user in Table 51…
please check and try to implement your logic…
If you are not using User setup then set Register time to true on General Ledger Setup.
dear pressi,
Did you ever find a solution to your problem? If you did, would you mind sharing it with us and if any of the posted answers helped you on the way, then please verify them.
Thank you.
