Hi guys,
I get an error message when trying to write a value in a field of a mapped table in a post routine.
Error msg is “The field with the RecID doesnt exist”. It comes just before the record is inserted (and I tried also After the insertion - still the same error). (custvendtrans.insert())
The Table is called VendTrans and the map is called CustVendTrans. VendTrans has a custom field PurchID
I added a custom field to the map (also PurchId) but did not generate a map, which as I assume is the reason for the error.
Can you help me how to generate a mapping?
Thanks in advance
