How i to know whether particular AOS instance is installed workflow are not?
when i run ax2009 setup workflow is disabled? is it possible to install workflow in single instance?
Hi
You can do this one go provide the system has share point portal installed in advance while installing it will create a workflow portal. After Ax installation you need to validate the portal and configure that in AX in a single go and use workflow
Regards
