I am trying to figure a solution whereby we have several approval groups to release a sales order but only one member from each group needs to approve.
For example
Sales Order gets released
Sales Order gets put in pending approval
Sent to engineering group to see if possible to make (many members but only needs one approval)
Sent to buyer group to check materials (many members but only needs one approval)
Sent to production group (many members but only needs one approval)
set the sequence of each member in the workflow group to 1.
Then in the workflow itself, change the condition for “An approval request approved” to ‘’ & delete the line “An approval request approved” Condition: ‘Pending Approval:>0’.
The first change allows anyone in the workgroup to approve the request. the deletion removes the condition that waits for other members of the group to approve the request.
I see how this works with 1 user group, however, how would this then work to make it so that another approval request is now sent to a different group?
in the response create a new line to create the approval request user approver type Work Flow User Group and then select the group you want the notification to go to.
looks like you’ve drilled into a response after your very first event.
My first event is something like “Approval of purchase document is req…” - its the response for this event I drill into to get to the option to send notifications to more than one group…
