Hello Everyone, I have designed a custom workflow on a standard D365 Form and I have encountered an issue. When I assigned the workflow to a user. Upon clicking the id on work item assigned form, the link redirects them to an empty record, even though the form for the same record contains data.
Below picture show the record when opened through the workflow item assigned link:
Hi Abdul,
I am also facing exactly same issue.
What is the the solution for this ?
Could you please help with this.
Based on the screenshot, I’d suggest checking the following:
First, make sure the correct form layout is assigned to the user role, especially for fields like Major type or Unit cost. Sometimes fields aren’t visible if the form is not set up for the user’s security role.
Also, ensure all required fields are populated, especially fields like Quantity or Unit cost. These might be blocking the record from saving properly.
