Does Navision contain any functionality to manage workflows? i.e. to automatically create tasks for different employees.
Or is a seperate workflow program needed? Does anyone know if any programs have been interfaced to Navision?
Tectura has an add-on that does this wonderfully. Check out this link: http://www.in.tectura.com/doccenter/Newsletters/WorkflowSalesA4_FS-1.pdf
Navision don’t have any real workflow. There is document approval concept but is a basic workflow implementation. You must look at add-ons.
For Navision 5.0 was talked about workflow implementation using SharePoint, but it never came out.
Hello,
There is a workflow solution for NAV.
agilesWorkflow is a NAV add-on that handles workflow requirements completely within the Navision solution. Whether you need to manage simple workflows or very complex workflows, or for processes across several different business areas, agilesWorkflow can manage all these because workflows can be run from any area in NAV. It also works seamlessly with customer customizations or vertical add-on solutions.Also it a solution for all kinds of NAV users, we have agilesWorkflow with 5 NAV users up to 900 NAV users.
For more information, you can now find the agilesWorkflow brochure, as well as the agilesWorkflow DVD which contains short demonstration films, in the Downloads section.
