Workflow escalation to next level in hierarchy
I am in the process of configuration the purchase requisition workflow.
My “approval” step is using the organizational hierarchy and approval limits assigned to each person in the hierarchy - this is all working well.
I am now trying to set up an escalation which I thought would be quite simple: If an approver did not approve within 2 days (for example) - I want the workflow to escalate the next level above them in the hierarchy.
so on the approval step, I turn on the “Use Escalation Path”, and I assume the “Assignment Type” should be “Hierarchy”?
On the “hierarchy selection” what should I select?
Or is it done completely differently?
I assume the "
I think that looks right. Are you seeing error messages in the workflow history?
Any solution?
I also have escalation requirement(Eg: 2days time limit) in workflow.
You’re on the right track. In Finance & Operations, escalation is configured on the same approval step that uses the organizational hierarchy.
For Purchase Requisition workflows, what usually works is:
  • Enable the use of the escalation path on the approval step
  • Set Escalate after (for example, 2 days)
  • Choose the Assignment type as Hierarchy
  • In Hierarchy selection, select the same Position hierarchy that you are using for approval
Escalation moves the approval one level up in the same hierarchy. If the current approver does not take action within the defined time, the workflow looks for the parent position and assigns it to the next level above.
If escalation does not trigger, check that:
  • The approver’s position has a parent in the hierarchy
  • The hierarchy is assigned to the worker’s position
  • Workflow batch jobs are running
Keeping approval and escalation on the same position hierarchy usually gives the expected result.
@Hardik_Gupta if I follow your instructions, the workflow “escalates” to the same person it was on previously, so that’s not an escalation at all.
@Musty no solution as of yet, and I already have the same issue with a new project…
Personally I find it a bit frustrating how the D365 Workflow engine cannot satisfy out of the box some very straight forward and common business use cases.
Hi @zvika.rimalt
This is expected behavior in D365 F&O.
Hierarchy escalation only works if moving up the hierarchy results in a different worker. If the parent position is assigned to the same person (or is vacant), the workflow will reassign it to the same approver.
Things to check:
  • The approver is not assigned to both the current and the parent position
  • The parent position is active and assigned to a different worker
If you need escalation to always go to another person, hierarchy escalation alone won’t guarantee that. Common approaches are:
  • Add a second approval step with a time-based condition and assign it to a higher role or position
  • Use a specific user or role for escalation
My hierarchy is set up that every position is set to another person.
Yet, when I follow your instruction for escalation, and the workflow escalates, it goes to the same user.
which makes sense - I select the same hierarchy as originally, with the same approval levels. to the workflow gets assigned to the same person on the hierarchy tree as before the escalation.
Hi @zvika.rimalt
Yes, I agree with you. What you’re seeing makes sense based on standard D365 F&O behavior.
Out of the box, escalation re-evaluates the same approval step using the same hierarchy and approval logic. It doesn’t automatically move to the next level above the current approver, so it can resolve back to the same user. This can also vary depending on system setup, integrations, or customizations.
In most cases, teams handle this by adding a separate time-based approval step or assigning escalation to a specific role or position. Otherwise, some customization is required.
I may not be deep on the technical side, but if you want, we can review your setup together. Happy to arrange a quick call with our D365 F&O techno-functional consultant if that helps.
talking with you feels like speaking with Chat GPT
Thank you! I take that as a compliment
Hello Zvika,
Thank you for bringing this up. I tested the setup on version 10.0.46.
I expected the escalation to move up from whoever had the task. I found that the escalation searches again from the requester, so with the same settings as the approval step, the escalation picks the same approver.
What worked for me was 1 approval step per amount range, for example up to $1,000 and from $1,000 to $5,000. Each step has escalation rows that stop at the next approval limit. A $500 request then went from the Lead to the Manager, and then to the Director.
When the step for small amounts was missing, a $500 request was approved automatically (this to me is a red flag).
Blog: Procurement and Sourcing: Workflow Escalation Returning to the Same Approver in Dynamics 365 Finance ; Procurement and Sourcing: Workflow Escalation Returning to the Same Approver in Dynamics 365 Finance - DEV Community
Hi Dean, thanks for your response.
This sounds like a creative solution.
Are you saying that you put the approval steps parallel to each other and used a condition step to direct the workflow to the proper amount?
Or you put the approval steps in sequence, one after another, with a condition to skip the approval steps with an amount too low?
I would say that the latter is closer. Indeed the approval steps are arranged in sequence, and the workflow is as follows: Start → ESC band A → ESC approval → End. Both steps are in the same approval element without separate condition step.
ESC band A applies to amounts up to $1,000, and ESC approval to amounts above $1,000 and up to $5,000. For a $3,000 request, the workflow history recorded ESC band A as False and ESC approval as True, so only ESC approval ran.
I hope testing is not too much effort, Zvika.
