Workflow error
Hello,
I am getting the following error while trying to submit the workflow in timesheets.
Please find the path where i am getting this error:ProjectManagement & Accounting>Common>TimeSheets>take any time sheet with status “Draft” and when I am trying to submit the workflow here I am getting this below error. Please help in this,this is actually happening in our production.
“Function ProjBudgetTransactionLine_Virtual::construct has been incorrectly called.”
Thanks in Advance!!!
Why don’t you compile the Timesheet related objects once and then check if the problem is still happening?
FYI they start with TS pre-fix for example TSTimesheetTable.
I tried it,but unfortunately it’s not resolved. Thanks
