Workflow Error
Hi Experts,
While creating new workflow I am facing this error.
Error executing code: FormRun (data source) has no valid runable code in method ‘new’.
Stack trace
(C)\Classes\FormRun\new
(C)\Classes\SysSetupFormRun\new - line 4
(C)\Classes\ClassFactory\formRunClassOnClient - line 10
(C)\Classes\ClassFactory\FormRunClass - line 24
(C)\Classes\xMenuFunction\run
(C)\Classes\MenuFunction\run - line 85
(C)\Classes\SysWorkflowConfigurationListPage\main - line 55
(C)\Forms\WorkflowTableListPage\Data Sources\WorkflowTable\Methods\create - line 31
(C)\Classes\FormRun\createRecord
(C)\Classes\FormRun\task
(C)\Classes\SysSetupFormRun\task - line 20
Please help me to resolve this issue.
Nitish
What is the AX version? Which workflow you are trying to create? Please elaborate…
Hi Kranthi,
Thanks for reply, I am using AX 2012 R2, CU7 Version . I am trying to create workflow for purchase requisition.
I am following the this step
Procurement & sourcing > setup > Procurement and sourcing workflows > Click on New (or Edit) button
then I am getting this error.
But trying to create any type of workflow then I am getting same error.
Nitish
Is your application fully compiled?
Hi Martin,
Thanks for reply, I am not sure about this because I am not taking care of this Admin activity.
But this environment is created 2 month before and at that time compilation has been done.
Then what need to do next.
Compile the application and check if you are still getting this error.
