When I want to create a new workflow for purchase orders in Dynamics AX 2012 R2, I receive this error message:
Workflow threw an exception for the following reason: Énumération avec ‘0’ inconnu.
can some one help me
Can you tell us the exact steps that you followed?
I click on the link : Procurement and sourcing–>Setup->procurement and sourcing workflows.
After I click in New button to create a new workflow based on a type
I chose purchase order workflow and I click in “create workflow” button
I get the error : An unexpected error has occurred while opening the workflow. See the event log on the AOS and contact your system administrator to resolve the issue.
In the event Log I Have this error: Workflow threw an exception for the following reason: Énumération avec ‘0’ inconnu.
thanks for help
Hi MST,
have you find the solution to this problem, i’m also facing the same.
Please let me know.
Thanks & Regards
Vijay Raj Nath
Better compile the application once and re-generate the full CIL.
