Hi
In the workflow configuration process we have a field called Assignment type field and it has the 4 options.
Paticipant
Hierarchy
workflow user
user.
Could any one explain the above options with an example ?
Hi
Paticipant
Hierarchy
workflow user
user.
Participant: Users who are assigned to a specific group or role. In this type you can assign the task to a role instead of specific user. For example, if you want to assign the task to Purchase manager role, use this type.
Hierarchy: Users in a specific organizational hierarchy. In this type:
For example if you want to assign the task to the next step in the hierarcy ( can be department manager) of the creator of the purchase requsition, use this type. Or you want to assign the task to the highest level manager in requester department.
Workflow user : Users in the current workflow. For example; if you want to assign the task to workflow creator, you can use this type.
User: Specific Microsoft Dynamics AX users. İf you want to assign the task to a spesific name whatever his/her position and hierarchy in the company, use this task.
