Work Order Ending Issue
I need to end a work order but i cant end it. System Says the following error message
Active job registrations or journal registrations exist on production in Manufacturing Execution
Update has been cancelled.
I go to view → Job Card and check every work journal and transfer every employee in the Job Card from the time and attendance module. But still unable to end the work order. Please help me to fix this issue.
Best Regards,
Kasun Deshapriya
check this link here you can find solution.
community.dynamics.com/…/187877
Thank you for the reply. But still i cant end the production order.
It seems that there are few Job registration exists which are still pending to transfer.
The pending job registration can be seen using inquiries–>registration–>journal registrion. request you to filter with production no in the reference column. Hopefully there should be some records available.
Any reason this is in the developer forum?
HI Salman
I cannot find the path you mentioned in Dynamics 365. Can you specify the full path
Regards
Kasun Deshapriya
No, I have posted in wrong Forum. Sorry for that. But I hope a reply to solve my issue. Please kindly help me to fix this issue.
Thank you
Moved to user forum and deleted your duplicate post in the user forum.
Go to Production Control>>MES>>Jobs and Activities>>Production Jobs.
From there you can view registrations. There are other places and the number of menus are small so I am not sure given Salman telling you to look at the job registration why you could not find it?
