We have two locations Blue ,Green.
Blue is the raw material location , Green is the Production Location.
Generally we transfer the Item from locatin Blue to Location green .
Suppose I transferred Item A, ( Ramaterial) quantity 100. in the month July to location Green.
At the end of month July 50 qty is consumed .
25 qty is work in process,
25 is available in Green location.
What do you want the report to say - consumed, WIP and Available?
What is your WIP process? Have you looked at the Inventory WIP valuation report? Have you looked at the Inventory Transaction Detail report?
I would guess there will not be a report in teh format and structure you require, so you will probably have to think about how you get this information out in tandem to the processes in place.
Firstly it depends upon your WIP definition and how you are processing consumption through NAV. Secondly once you understand this if there is no standard report meeting you needs you would need to ask a developer how to extract the data in teh required format.
Yes it is possible using the item ledger entry table and looking up the production order table. You will have to assign the location on the production order to maintain the link for the WIP calculation.
