Word Automation Error
I have made one customization for our customer where for particular customer, the confirmation letter will be generated giving details of the balance amount till date or any date filter.
Now i used word automation for generating the letter.
In the classic version on forms this code is working fine but as i move to RTC page i got error which states that:
This message is for C/AL programmers: The call to member ActiveDocument failed: This command is not available because no document is open…
Please help…
Is ServiceTier installed in some other system?
If yes, When you are searching for a file from RTC, it wills earch for path in Servicetier installed system not on client machine…
Hi Mohan,
I am using the server of the client where the navision is installed and i have placed file there…
Can you show us the code what you are trying?
Can you please give me you mail id so that i can send you the codeunit i had created for this…
Even i had tried to give file path based on the server ip but in this it gives error as the file is corrupted but for the same path in a classic client its working fine…
You have upload your file to servicetier installed system before trying to open it…
Check report 9172 how upload function to use…
make sure the difference between server system and servicetier system…
Tried using this also…it asks for file to be uploaded and then the same error comes…
no file is open
[:S]
