Accounting Periods in NAV is somewhat rather embrional - mostly for reporting purposes only, and based on Posting Dates anyway. (You define start/end dates for Periods, and that’s all)
For full-blown AP system there should be a AP field in GL entries, and no direct link between Posting Date and Accounting Period.
added/ Then you could have, for example, 12 months, Year Closing Period where all closing transactions goes (NAV solves this by means of closing dates like C31/12/2008) and Audit Period, where auditor’s corrections are posted… /added
If you want to avoid postings in past / future, set Allowed posting From & To dates in GL Setup.
Nothing is wrong, you can post without an existing account period. Only filter experessions like p1…12 or Y won’t work as usual, the end date is then 31.12.9999
If you want to prevent posting into false periods, use either “Allow Posting From”/“Allow Posting To” in the General Ledger Setup or in the User Setup ( overrides the G/L Setup).
If any of the answers helped solve your problem, then please click on the “Verify Solution” (you need to be logged in to see this). This helps us see that your problem was solved. If not, then please post additional information.
