Hello There,
When I opened the NAV (5.0) database from SQL Management Console (for Reporting from outside NAV) it is noticed that the Table 200…54 - Windows Login as well as Table 200…53 - Windows Access Control has only the SID column where if we read the table from object designer we can see User ID and Name columns. Does anybody has any idea how or if they are hiding it and if I need the User ID to be listed using an SQL Query how should I do that.
Regards
Najja
