Windows Firewall - Ports
Greetings,
At my client got one DB server and AX/AOS server.
All was working fine. Suddenly when I enabled the Windows Firewall. The AX stopped working, the AOS service itself not running.
By going thru different steps…Finally found its due to windows firewall.
now in AOS/AX/Application Server windows firewall is ON. After I close DB Server windows firewall. AOS is working.
Can anyone tell me how to keep windows firewall ON in Database Server and at the same time AOS/AX server should work.
  • How to enable or what port I should add in inbound/outbound in firewall.
Regards
It seems the TCP port 1433 and 1434 are something you should open. See this msdn.microsoft.com/…/cc646023.aspx
