I am getting this error after upgrading to Windows 7 and running Dynamics NAV 4.3
There are erros in the text conversion (text no 146-100 does not exist in the .stx file). Internal error:47-1.
Any solutions?
Thanks.
Cathlyn
Any solutions?
Thanks.
Cathlyn
Window vista & 7 is not support Nav 4.3 version.so either you work with XP if you work with NAV 4.3 or either use NAV 2009.
True, but not fully. You can run 4.0 SP3 on Windows 7 making use of the XP mode. Have a look here on details and download: http://www.microsoft.com/windows/virtual-pc/download.aspx.
Hi, You can run 4.0 SP3 on Vista, if you get a special hotfix. I don’t know if this version if compatible with windows 7.
So, you are saying I need to speak to Microsoft to get this special hotfix?
