windows 2003 terminalserver and navision 3.60
Hi! I have installed the terminalservices (120 days) on a windows 2003 server. When I try to install attain 3.60 (minimum version) in the add/remove software window navision setup is at the end cancelled! How could I get navision on my windows 2003 server? Thanks Fred
Try going into Install mode and then running the setup program using the start/run command.
