anyone can tell me? what is the concept behind this?
Window.OPEN(
‘Processing …’ +
‘@1@@@@@@@@@@@@@@@@@@@@@’);
Thanks a lot.
Window.OPEN(
‘Processing …’ +
Thanks a lot.
Did you read this C/SIDE help topic already? How to: Create a Progress Window
hi,Luc,your tip is really useful. it helps me understand how to create a progress window,with "#"sign(which displays the field being updated ). however,it doesn’t tell what it means with "@"sign. can you further give me more guidance? because i can’t google it thank you.
as i have googled just now, http://www.mail-archive.com/navision-knowledge-village@yahoogroups.com/msg01161.html
it tells me that The “@” sign signifies that you want to use progress bar indicator. but i still feel confused. is it right if i understand this way: the number of "@"sign indicates the length of the indicator bar.?
Hi Edward
Windows are used to show whic record is durrently processing;
Just post a purchase/Saels order while posting a small window will be open.
In that window you can seen some fields.at the time of coding the length of that fields will be defind as ## or @@.
Lets take Processing…’+@@@@@’ as example here @@ symbol is pointing Size of the processing field in that window.
Jerome Marshal.J1832.Window.bmp (1.27 MB)
Thank you very much. i think i figure it out now. Thank you both.
