When I try to run best practice check on menuitem in AOT the client crashes. Checks of other parts AOT (tables, Forms, etc.) works fine.
I debug the best practice check starting with SysBPCheck::main. I go step by step until I go into SysBPCheckMenuFunction.workflowIgnoreList there on the line 34 is for cycle doing find all workflow approvals, add their event handler menu items to ignore list.
When it hits line with
Path: \Workflow\Approvals\RetailCatalogApproval Layer: sys
than the client crashes.
What can cause it and how can I repair it?
