Hello Friends,
I have struggled with a Query written in embedded SQL and converting it into Query API.
Query in pure SQL is below:
while select custTable
where custTable.AccountNum == ‘1102’
join priceDiscTable
where priceDiscTable.AccountRelation == custTable.AccountNum
join inventTable
where inventTable.ItemId == priceDiscTable.ItemRelation
join inventTableModule
where inventTableModule.ItemId == inventTable.ItemId &&
inventTableModule.ModuleType == 2 &&
inventTableModule.UnitId == ‘ea’
and when I try to convert it into Query API it is as follows but doesn’t work as upper pure SQL one.
static void a0_DynamicQueryJob(Args _args)
Query query;
QueryRun queryRun;
QueryBuildDataSource custTableDS;
QueryBuildDataSource priceDiscTableDS;
QueryBuildDataSource inventTableDS;
QueryBuildDataSource inventTableModuleDS;
QueryBuildRange queryBuildRange;
QueryBuildRange queryBuildRange2;
CustTable custTable;
PriceDiscTable priceDiscTable;
InventTable inventTable;
InventTableModule inventTableModule;
PriceDisc priceDisc;
query = new Query();
custTableDS = query.addDataSource(tableNum(CustTable));
SysQuery::findOrCreateRange(custTableDS, fieldnum(CustTable, AccountNum)); // In SysQueryForm 1102 is given
priceDiscTableDS = custTableDS.addDataSource(tableNum(PriceDiscTable));
priceDiscTableDS.relations(true);
priceDiscTableDS.joinMode(JoinMode::InnerJoin);
priceDiscTableDS.addLink(fieldnum(CustTable, AccountNum), fieldnum(PriceDiscTable, AccountRelation));
inventTableDS = priceDiscTableDS.addDataSource(tableNum(InventTable));
inventTableDS.relations(false);
inventTableDS.joinMode(joinMode::InnerJoin);
inventTableDS.addLink(fieldnum(PriceDiscTable, AccountRelation), fieldnum(InventTable, ItemId));
inventTableModuleDS = inventTableDS.addDataSource(tableNum(InventTableModule));
inventTableModuleDS.relations(false);
inventTableModuleDS.joinMode(joinMode::InnerJoin);
queryBuildRange = inventTableModuleDS.addRange(fieldnum(InventTableModule, ModuleType));
queryBuildRange.value(SysQuery::value(“2”));
queryBuildRange = inventTableModuleDS.addRange(fieldnum(InventTableModule, UnitId));
queryBuildRange.value(SysQuery::value(“ea”));
inventTableModuleDS.addLink(fieldnum(InventTable, ItemId), fieldnum(InventTableModule, ItemId));
queryRun = new SysQueryRun(query);
queryRun.prompt();
while(queryRun.next())
custTable = queryRun.get(tablenum(CustTable));
priceDiscTable = queryRun.get(tablenum(PriceDiscTable));
inventTable = queryRun.get(tablenum(InventTable));
inventTableModule = queryRun.get(tablenum(InventTableModule));
info(strfmt("%1 %2 %3 %4 %5 %6",
custTable.AccountNum,
priceDiscTable.price(),
priceDiscTable.Percent1,
priceDiscTable.Percent2,
inventTable.Itemid,
inventTable.ItemName));
Upper pure SQL query returns multiple rows which is right I thing but Query below returns only one row which is wrong.
Can anyone notice what I’m doing wrong?
Thanks for all,
Michael
