Steps:
1)Install NAV Classic connector msi.
2)Update the fin license and import the FOB file from Object Designer.
Expected result - The fob file should be imported successfully and no error shoul be shown.
Actual result - An error message is displayed saying " The compiler found 1 error while import or restore."
note : No compiler error found on Developer Box , throws compiler error on the QTesting Environment
I have had issues with the way NAV Classic was installed. My vendor would send me new objects and I would have compile issues as you described. In order to understand which object failed to compile, I go to Object Designer, All - Select all and run Compile. I then look at View → Marked Only. I also reinstalled the Classic Client and selected Outlook Integration (so that I could eliminate issues that were related to the fact that I had not installed this).
Good luck. Sue
Thanks Miller ,
i exported the objects (compiled) & unchecked the compile as in Nav 2009 it’s import + compile … & in Nav 2009 SP1 only import
