How Target License plate automatically come on Mobo screen when we are doing Inbound (Purchase Receive Process)
Where we do setup for target Licence plate
Thanks and regards,
D Praveen Kumar.
Thanks and regards,
D Praveen Kumar.
Hello Praveen,
Generate License plate checkbox available on Mobile device menu item e.g. Purchase receiving menu item. It help auto generate LP based on number sequence defined on parameter form.
Navigation path- Warehouse management > Setup > Mobile device > Mobile device menu item.
hi kunal thanks for reply, but i am asking about target license plate
Hello Praveen,
if you will do partial picking then system will use target LP ,
if your doubt is how you can enter target LP manually then you can do it by enable the option of override target license plate on mobile device menu item.
actually i am not doing partial picking and that “override target license plate on mobile device menu item” is also not enabled. but on mobo screen i can enter manually .system accepting.
license plate is connected with Location. but for target license plate. is there any relation with Location ??
are you using license plate controlled location?
is ‘Use license plate tracking’ option ticked on location?
Yes.
