where to specify the threshold value for "Minimum" countring group
I created a counting group which counting code is “Minimum”.
on the released products form, i select a specific released product and associate the counting group with it. but not sure i have to specify the “Threshold Value” for this item?
if i click the “Warehouse items” in “Order Settings” group of the “manage inventory” action bar, i found the default setting for the warehouse items doesn’t have a warehouse specified, and i also cannot change it. suppose i create multiple warehouse items here, what’s the impact ?
many thanks.
The default warehouse item is blank, as a coverall of ALL warehouses, you need to create a new one for each warehouse, and when using minimum it counts when the on hand is less than the picking minimum defined on the warehouse item.
You should create multiple warehouse item records, especially if you want to use the counting group minimum functionality.
