Yes and that’s how I’ve done it many times before! But this time we couldn’t get any NAV icon from FIN.EXE (of FINSQL.EXE or any of the other files)… That’s the whole mystery!
maybe its a specific version of fin.exe that has them missing. Did you try a different fin.exe, say 4.00. You should be able to just copy the exe onto the computer, no need to install or anything.
The thing is though that I have had so many bizzare things happen on TS and Citrix, that I do believe it could happen.
As far as I remember then we came down to the fact that we somehow where refering to the exe-file on the Citrix named machine instead of from an exe file directly on the same machine as the Citrix Management Console.
That makes sense. would recommend just copying the fin.exe to the remote computer and using the icon locally. It could be somethign as simple as a VPN issue blocking direct access to EXE, or may be the port used.
Oddly it does not even show any normal Nav icons or the old financials one, just the devloper type icons. We have 4.00 on the same machine and that works fine. If we point to the 4.00 exe file it doesn’t even find the 4.00 icons.
