I have two diferent Nav Instalations: Nav 5.0 in spanish and Nav 2009 in frech.
Our headquarters are in Spain, and I want to execute both in the same computer and using spanish language.
Ok, I found how to install both clients (classic) and store both fin.zup in order to have to independent installations in my computer. Now I have to translate the french database into spanish and I’m in trouble with it.
My Nav partnert send me the translation module and documentation, but when I import the language module, I get some errors. I did it without problems for menuitems and forms, but when I import the module into tables, I found the following error: “Could not load the selected type library”
I sent it to my Nav partner, and they sent it to MS, but I have not response and need to work with it
Then, I tried to found where in the DB are the foreign caption stored. I’m comparing two DBs, the original one and this I imported the language module. I don’t find the texts anywhere.
But, does that it mean that it’s somewhere in the database and I can update them from my spanish version of the database using the object’s id to join them?
Yes, as I said in my first message, I’m importing the spanish language module into my french DB, and I’m getting this error when translating tables: “Could not load the selected type library”. So, ¿what can I do?
Yes, it is somewhere in the database. I cross checked using W1 version. I do not have a localized version thus I am not able to check that. To get an idea; have you tried this quick check; exporting as text the same object number from the two databases and comparing them? Will this possibly give you the lead that you need?
I compiled all the tables and had an error result on one of them and a warning in another one. I excluded them when importing the language module and voila!!! Perfect
Thank you very much, I’m going to compile all the objects and try again.
Thanks, Abiola. I used Red Gate’s Data Compare utility to compare the DB with a restauration from the original state, and didn’t find anything, but I’ll try this way too
