Hi All
When “initFromInventTable()” is called in SalesLine Table?
Share your ideas?
I want to trigger an action while calling that method.
Thanks in Advance…[:)]
Hi All
Share your ideas?
could you explain me detail…
It should be after ItemId modified action
Hi Kranthi
In which Form’s/Table’s ItemId Modified()
Pls explain this…
salestable form → salesline_ds → item id modified () i guess.
Put a break point in the form data source - Item Id modified method and start debugging
Hi Bobby,
this is flow of method call.
Kep the breakpoint in the Table – salesLine – method – initFromInventTable…you can find the flow of execution the call stack window…
Forms\SalesTable\Data Sources\SalesLine\Fields\ItemId\Methods\modified
Forms\SalesTable\Data Sources\SalesLine\Methods\itemIdModified
Data Dictionary\Tables\SalesLine\Methods\itemIdChanged
Data Dictionary\Tables\SalesLine\Methods\initFromInventTable
Naresh.
Hi Naresh,
It is solved for me Thank you.
